소개
This is a straight-forward process that requires removal of a few screws and two wire caps.
필요한 것
Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
거의 끝나갑니다!
To reassemble your device, follow these instructions in reverse order. Make sure to correctly replace the wires using tape you placed earlier as a reference.
결론
다른 2명이 해당 안내서를 완성하였습니다.
