주요 콘텐츠로 건너뛰기
Hamilton Beach 25460Z Plug Wiring Replacement
필요한 것
  1. Hamilton Beach 25460Z Plug Wiring Replacement, Plug Wiring: 1 단계, 이미지 1/2 Hamilton Beach 25460Z Plug Wiring Replacement, Plug Wiring: 1 단계, 이미지 2/2
    • Unplug your device before proceeding with disassembly.
    • Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
  2. Hamilton Beach 25460Z Plug Wiring Replacement: 2 단계, 이미지 1/1
    • Lift up the plastic cover to expose the plug wiring.
    • Mark the plug wire connected to the red wire with a piece of tape. This will be used as a reference for reassembly.
  3. Hamilton Beach 25460Z Plug Wiring Replacement: 3 단계, 이미지 1/3 Hamilton Beach 25460Z Plug Wiring Replacement: 3 단계, 이미지 2/3 Hamilton Beach 25460Z Plug Wiring Replacement: 3 단계, 이미지 3/3
    • Use the pliers to pinch the widest point of the cap. This should be done opposite of the already existing crimps.
    • Slide off the white cap.
    • Repeat these steps for the second white cap.
  4. Hamilton Beach 25460Z Plug Wiring Replacement: 4 단계, 이미지 1/2 Hamilton Beach 25460Z Plug Wiring Replacement: 4 단계, 이미지 2/2
    • Remove the two rubber screw covers from the bottom of the Panini Press.
    • Remove the four uncovered 10mm screws with the PH2 Screwdriver.
  5. Hamilton Beach 25460Z Plug Wiring Replacement: 5 단계, 이미지 1/2 Hamilton Beach 25460Z Plug Wiring Replacement: 5 단계, 이미지 2/2
    • Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely.
결론
To reassemble your device, follow these instructions in reverse order. Make sure to correctly replace the wires using tape you placed earlier as a reference.
다른 2명이 해당 안내서를 완성하였습니다.
Maxwell Taylor
회원 가입일: 02/08/15
149 평판
안내서 1개 작성함
Cal Poly, Team 6-27, Amido Winter 2015 Cal Poly, Team 6-27, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G27
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 657
