주요 콘텐츠로 건너뛰기
Hamilton Beach 25460Z Thermal Switch Replacement
필요한 것
  1. Hamilton Beach 25460Z Thermal Switch Replacement, Plug Wiring: 1 단계, 이미지 1/2 Hamilton Beach 25460Z Thermal Switch Replacement, Plug Wiring: 1 단계, 이미지 2/2
    • Unplug your device before proceeding with disassembly.
    • Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
  2. Hamilton Beach 25460Z Thermal Switch Replacement: 2 단계, 이미지 1/1
    • Lift up the plastic cover to expose the plug wiring.
    • Mark the plug wire connected to the red wire with a piece of tape. This will be used as a reference for reassembly.
  3. Hamilton Beach 25460Z Thermal Switch Replacement: 3 단계, 이미지 1/3 Hamilton Beach 25460Z Thermal Switch Replacement: 3 단계, 이미지 2/3 Hamilton Beach 25460Z Thermal Switch Replacement: 3 단계, 이미지 3/3
    • Use the pliers to pinch the widest point of the cap. This should be done opposite of the already existing crimps.
    • Slide off the white cap.
    • Repeat these steps for the second white cap.
  4. Hamilton Beach 25460Z Thermal Switch Replacement: 4 단계, 이미지 1/2 Hamilton Beach 25460Z Thermal Switch Replacement: 4 단계, 이미지 2/2
    • Remove the two rubber screw covers from the bottom of the Panini Press.
    • Remove the four uncovered 10mm screws with the PH2 Screwdriver.
  5. Hamilton Beach 25460Z Thermal Switch Replacement: 5 단계, 이미지 1/2 Hamilton Beach 25460Z Thermal Switch Replacement: 5 단계, 이미지 2/2
    • Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely.
  6. Hamilton Beach 25460Z Thermal Switch Replacement, Thermal Switch: 6 단계, 이미지 1/2 Hamilton Beach 25460Z Thermal Switch Replacement, Thermal Switch: 6 단계, 이미지 2/2
    • Remove the two 10mm screws connecting the thermal switch with the PH2 Screwdriver and a bit of force.
    • These screws may be difficult to remove.
  7. Hamilton Beach 25460Z Thermal Switch Replacement: 7 단계, 이미지 1/1
    • De-solder the connection between the wires and the thermal switch.
    • Refer to this page if you need to brush up on your soldering skills.
    • Replace the thermal switch.
    • The lead on the red (with the small hole), marked in red, connects to the white wire.
    • The lead on the right, marked in blue, connects to the blue wire.
결론
Forrest Rodeman
회원 가입일: 02/01/15
318 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-27, Amido Winter 2015 Cal Poly, Team 6-27, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G27
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 1,898
