주요 콘텐츠로 건너뛰기
Hamilton Beach 48464 Heating Plate Replacement
필요한 것
  1. Hamilton Beach 48464 Heating Plate Replacement, Heating Plate: 1 단계, 이미지 1/1
    • To begin, carefully open the top lid of the Brew Station.
  2. Hamilton Beach 48464 Heating Plate Replacement: 2 단계, 이미지 1/1
    • Gently pull out the filter basket from the Brew Station and set it to the side.
  3. Hamilton Beach 48464 Heating Plate Replacement: 3 단계, 이미지 1/1
    • Grab the handle and pull up to remove the top container.
    • Set this piece close by as you will be needing it for a future step.
  4. Hamilton Beach 48464 Heating Plate Replacement: 4 단계, 이미지 1/2 Hamilton Beach 48464 Heating Plate Replacement: 4 단계, 이미지 2/2
    • Using the Crown Bolt #8 Steel Spanner, unscrew the four 8-mm screws labeled in a red outline.
  5. Hamilton Beach 48464 Heating Plate Replacement: 5 단계, 이미지 1/2 Hamilton Beach 48464 Heating Plate Replacement: 5 단계, 이미지 2/2
    • Check again to make sure that the coffee maker is not plugged in.
    • Once the screws are removed, carefully pull off the metal piece.
    • Once the piece is removed, you will be able to access the heater.
  6. Hamilton Beach 48464 Heating Plate Replacement: 6 단계, 이미지 1/2 Hamilton Beach 48464 Heating Plate Replacement: 6 단계, 이미지 2/2
    • This step involves using the top contained that you put aside in step 3.
    • Using the Philips 2 Screwdriver, unscrew the eight 8-mm screws labeled in a red outline.
  7. Hamilton Beach 48464 Heating Plate Replacement: 7 단계, 이미지 1/1
    • Once screws are removed, carefully pull out the metal piece from the unit. This is the top part of the heater in the Brew Staton.
    • There are rubber washers inside each of the 8 holes on the piece of metal. Be careful to not let any fall out when handling the piece.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Damico
회원 가입일: 02/10/16
661 평판
안내서 6개 작성하였습니다
USF Tampa, Team 14-1, Lacy Spring 2016 USF Tampa, Team 14-1, Lacy Spring 2016 회원
USFT-LACY-S16S14G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 9
전체 시간: 942
