주요 콘텐츠로 건너뛰기
Hamilton Beach 48464 Power Cord Replacement
필요한 것
  1. Hamilton Beach 48464 Power Cord Replacement, Base: 1 단계, 이미지 1/1
    • This is what the bottom cover will look like. Flip the Brew Station upside down to easily access the screws.
  2. Hamilton Beach 48464 Power Cord Replacement: 2 단계, 이미지 1/3 Hamilton Beach 48464 Power Cord Replacement: 2 단계, 이미지 2/3 Hamilton Beach 48464 Power Cord Replacement: 2 단계, 이미지 3/3
    • Using the Philips 2 Screwdriver, unscrew the three 8-mm screws labeled in a red outline.
    • Using the Crown Bolt #8 Steel Spanner, unscrew the two 8-mm screws labeled in a orange outline.
  3. Hamilton Beach 48464 Power Cord Replacement: 3 단계, 이미지 1/1
    • Carefully slide off the bottom drip tray by sliding it out away from the Brew Station.
  4. Hamilton Beach 48464 Power Cord Replacement: 4 단계, 이미지 1/1
    • Gently lift the base away from the Brew Station.
  5. Hamilton Beach 48464 Power Cord Replacement, Power Cord: 5 단계, 이미지 1/2 Hamilton Beach 48464 Power Cord Replacement, Power Cord: 5 단계, 이미지 2/2
    • Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline.
  6. Hamilton Beach 48464 Power Cord Replacement: 6 단계, 이미지 1/1
    • Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline. This will release the bracket that is holding down the large piece in the middle.
  7. Hamilton Beach 48464 Power Cord Replacement: 7 단계, 이미지 1/1
    • Using one hand, gently lift the large silver piece out of the base.
    • The silver piece will still be connected to the Brew Station, so handy it with care.
  8. Hamilton Beach 48464 Power Cord Replacement: 8 단계, 이미지 1/1
    • Once the screw is out, gently lift the white circuit board out of the base. This will be where the power cord begins, so you will now have access to the full length of the cord.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Damico
회원 가입일: 02/10/16
661 평판
안내서 6개 작성하였습니다
USF Tampa, Team 14-1, Lacy Spring 2016 USF Tampa, Team 14-1, Lacy Spring 2016 회원
USFT-LACY-S16S14G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 9
전체 시간: 244
