주요 콘텐츠로 건너뛰기
Hamilton Beach 48464 Tubing Replacement
필요한 것
  1. Hamilton Beach 48464 Tubing Replacement, Filter Basket: 1 단계, 이미지 1/2 Hamilton Beach 48464 Tubing Replacement, Filter Basket: 1 단계, 이미지 2/2
    • Carefully open the top lid of the Brew Station.
  2. Hamilton Beach 48464 Tubing Replacement: 2 단계, 이미지 1/1
    • Slide out the filter basket that is sitting on top after opening the lid.
  3. Hamilton Beach 48464 Tubing Replacement, Tubing: 3 단계, 이미지 1/2 Hamilton Beach 48464 Tubing Replacement, Tubing: 3 단계, 이미지 2/2
    • Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline.
    • Once screws are removed, pull off the little circle piece.
  4. Hamilton Beach 48464 Tubing Replacement: 4 단계, 이미지 1/2 Hamilton Beach 48464 Tubing Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, grab the tube that is exposed after you pulled the piece off in step 1 and pull it up and out of the Brew Station.
  5. Hamilton Beach 48464 Tubing Replacement: 5 단계, 이미지 1/2 Hamilton Beach 48464 Tubing Replacement: 5 단계, 이미지 2/2
    • Using the Philips 2 Screwdriver, unscrew the three 8-mm screws labeled in a red outline.
    • Once screws are removed, gently pull off the liner that is on the inside of the lid.
  6. Hamilton Beach 48464 Tubing Replacement: 6 단계, 이미지 1/2 Hamilton Beach 48464 Tubing Replacement: 6 단계, 이미지 2/2
    • After completing Step 3, you will be exposed to a little piece attached to the inside of the lid. Pull this piece out, as it is the last piece of tubing used in the Brew Station.
결론
Michael Damico
회원 가입일: 02/10/16
661 평판
안내서 6개 작성하였습니다
USF Tampa, Team 14-1, Lacy Spring 2016 USF Tampa, Team 14-1, Lacy Spring 2016 회원
USFT-LACY-S16S14G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 779
