주요 콘텐츠로 건너뛰기
Hamilton Beach 49980A Motherboard Replacement
필요한 것
  1. Hamilton Beach 49980A Motherboard Replacement, Bottom Plate: 1 단계, 이미지 1/3 Hamilton Beach 49980A Motherboard Replacement, Bottom Plate: 1 단계, 이미지 2/3 Hamilton Beach 49980A Motherboard Replacement, Bottom Plate: 1 단계, 이미지 3/3
    • Begin by inverting the coffee maker and resting it on a flat surface to make working on the bottom easier.
    • Now use a Y0 bit to remove all of the .46 inch long screws from the bottom.
    • Lift the plate to remove it from the rest of the machine.
  2. Hamilton Beach 49980A Motherboard Replacement, Motherboard: 2 단계, 이미지 1/1
    • Once the bottom plate is removed, use a PH1 bit to remove the .525 inch long screws holding the motherboard bracket in the main housing.
  3. Hamilton Beach 49980A Motherboard Replacement: 3 단계, 이미지 1/2 Hamilton Beach 49980A Motherboard Replacement: 3 단계, 이미지 2/2
    • Using a PH1 bit, remove the two .425 inch long screws holding down the white power cord bracket. This will give you the slack in the wire that you need to work on the motherboard.
    • Carefully remove the large white connector that has multiple wires attached to it. This is the wire connected to the button functions on the interface of the coffee maker.
결론
Daniel Servant
회원 가입일: 03/25/16
301 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-7, Miles Spring 2016 UMass Dartmouth, Team 1-7, Miles Spring 2016 회원
UMASSD-MILES-S16S1G7
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
very informative and helpful.    I am anal about trying to repair different appliances.    I despise ‘throw away  and replace’  philosophy.   now I need to determine how to purchase a new motherboard.   at this point, I draw the line is trying to diagnosis and repair one.…………
john - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 793
