주요 콘텐츠로 건너뛰기
Hamilton Beach 49980A Power Cord Replacement
필요한 것
  1. Hamilton Beach 49980A Power Cord Replacement, Bottom Plate: 1 단계, 이미지 1/3 Hamilton Beach 49980A Power Cord Replacement, Bottom Plate: 1 단계, 이미지 2/3 Hamilton Beach 49980A Power Cord Replacement, Bottom Plate: 1 단계, 이미지 3/3
    • Begin by inverting the coffee maker and resting it on a flat surface to make working on the bottom easier.
    • Now use a Y0 bit to remove all of the .46 inch long screws from the bottom.
    • Lift the plate to remove it from the rest of the machine.
  2. Hamilton Beach 49980A Power Cord Replacement, Motherboard: 2 단계, 이미지 1/1
    • Once the bottom plate is removed, use a PH1 bit to remove the .525 inch long screws holding the motherboard bracket in the main housing.
  3. Hamilton Beach 49980A Power Cord Replacement: 3 단계, 이미지 1/2 Hamilton Beach 49980A Power Cord Replacement: 3 단계, 이미지 2/2
    • Using a PH1 bit, remove the two .425 inch long screws holding down the white power cord bracket. This will give you the slack in the wire that you need to work on the motherboard.
    • Carefully remove the large white connector that has multiple wires attached to it. This is the wire connected to the button functions on the interface of the coffee maker.
  4. Hamilton Beach 49980A Power Cord Replacement, Power Cord: 4 단계, 이미지 1/1
    • After removing the motherboard, follow the powercord down to where it splits. It will be connected to the motherboard in two places with solder. Locate these two points.
  5. Hamilton Beach 49980A Power Cord Replacement: 5 단계, 이미지 1/1
    • Using a soldering iron, heat up one soldered point that is holding the power cord in place. While the solder is hot, carefully pull the cord out of the connection.
    • The wire will be hot. You may want to use pliers to remove it.
  6. Hamilton Beach 49980A Power Cord Replacement: 6 단계, 이미지 1/1
    • Locate the second half of the power cord. On the underside of the motherboard, heat up the soldered connection and remove the wire while the solder is hot.
    • When replacing any soldered components, you may want to apply new solder.
결론
Paul Shipley
회원 가입일: 03/25/16
201 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-7, Miles Spring 2016 UMass Dartmouth, Team 1-7, Miles Spring 2016 회원
UMASSD-MILES-S16S1G7
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 9
전체 시간: 485
