주요 콘텐츠로 건너뛰기
Hamilton Beach 51101BA Blades Replacement
필요한 것
  1. Hamilton Beach 51101BA Blades Replacement, Blades: 1 단계, 이미지 1/1
    • Remove the lid from the container by holding the base and pulling up on the lid.
  2. Hamilton Beach 51101BA Blades Replacement: 2 단계, 이미지 1/3 Hamilton Beach 51101BA Blades Replacement: 2 단계, 이미지 2/3 Hamilton Beach 51101BA Blades Replacement: 2 단계, 이미지 3/3
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  3. Hamilton Beach 51101BA Blades Replacement: 3 단계, 이미지 1/3 Hamilton Beach 51101BA Blades Replacement: 3 단계, 이미지 2/3 Hamilton Beach 51101BA Blades Replacement: 3 단계, 이미지 3/3
    • Avoid placing your fingers on the blade, as they could be sharp.
    • Using a pair of pliers to hold the blade in place, use your other hand to unscrew the rubber piece on the bottom of the container.
    • Remove the rubber piece and the two washers by rotating the rubber piece counter-clockwise.
  4. Hamilton Beach 51101BA Blades Replacement: 4 단계, 이미지 1/1
    • Carefully, pull the blades out of the container as they are very sharp.
    • Using the pliers, remove blades and the washer around the blade shaft.
결론
To reassemble your device with the new blade assembly, follow these instructions in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
Brandon Nunez
회원 가입일: 08/28/15
283 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 3개
Need to know how to install parts and how many
papi3701@aol.com - 답글
Looks like I missed parts need to know the order son cuantaty
For my 501101B blender, the whole blade assembly popped out, so the blended smoothie draws at the bottom like a water falls How to fix this?
Joyful Joy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 20
30일 전: 98
전체 시간: 11,489
