주요 콘텐츠로 건너뛰기
Hamilton Beach 51101BA Power Cord Replacement
필요한 것
  1. Hamilton Beach 51101BA Power Cord Replacement, Power Cord: 1 단계, 이미지 1/3 Hamilton Beach 51101BA Power Cord Replacement, Power Cord: 1 단계, 이미지 2/3 Hamilton Beach 51101BA Power Cord Replacement, Power Cord: 1 단계, 이미지 3/3
    • Remove container from base.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Power Cord Replacement: 2 단계, 이미지 1/1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Power Cord Replacement: 3 단계, 이미지 1/1
    • Lift the two wires from the motor platform.
  4. Hamilton Beach 51101BA Power Cord Replacement: 4 단계, 이미지 1/1
    • Using the wire cutters, cut the end of the thick black wires.
결론
To reassemble your device, you must solder the new power cord to the thin black and thin gray wires, and follow the steps in reverse order. Requires soldering skills.
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Huff
회원 가입일: 09/04/15
568 평판
안내서 3개 작성하였습니다
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 14
전체 시간: 1,923
