주요 콘텐츠로 건너뛰기
Hamilton Beach 51101BA Rotor Replacement
필요한 것
  1. Hamilton Beach 51101BA Rotor Replacement, Rotor: 1 단계, 이미지 1/3 Hamilton Beach 51101BA Rotor Replacement, Rotor: 1 단계, 이미지 2/3 Hamilton Beach 51101BA Rotor Replacement, Rotor: 1 단계, 이미지 3/3
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Rotor Replacement: 2 단계, 이미지 1/1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Rotor Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
  4. Hamilton Beach 51101BA Rotor Replacement: 4 단계, 이미지 1/1
    • Unhinge the plastic motor platform from the blender.
    • You may need a plastic spudger to unhinge the motor platform from the blender.
  5. Hamilton Beach 51101BA Rotor Replacement: 5 단계, 이미지 1/2 Hamilton Beach 51101BA Rotor Replacement: 5 단계, 이미지 2/2
    • Using a spudger, carefully insert the tip into the coil of wire around motor.
    • This is used to hold the rotating piece of the motor still.
  6. Hamilton Beach 51101BA Rotor Replacement: 6 단계, 이미지 1/1
    • Remove the white rotor piece by rotating it counter-clockwise.
    • While rotating, make sure the rotating piece of the motor remains still.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Huff
회원 가입일: 09/04/15
568 평판
안내서 3개 작성하였습니다
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Hi, Any idea where to get a new rotor.
Allen Reed - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 30
전체 시간: 1,317
