주요 콘텐츠로 건너뛰기
Hamilton Beach 70730 Bowl Replacement
  1. Hamilton Beach 70730 Bowl Replacement, Bowl: 1 단계, 이미지 1/1
    • Unscrew the cover by turning it counterclockwise.
  2. Hamilton Beach 70730 Bowl Replacement: 2 단계, 이미지 1/1
    • Grab the scraper by the midsection to remove.
  3. Hamilton Beach 70730 Bowl Replacement: 3 단계, 이미지 1/1
    • Carefully remove the blades by lifting them off of the blade shaft.
  4. Hamilton Beach 70730 Bowl Replacement: 4 단계, 이미지 1/1
    • Rotate the bowl counterclockwise to release it from the base.
  5. Hamilton Beach 70730 Bowl Replacement: 5 단계, 이미지 1/1
    • Make sure there is no food or grime along the outside of the bowl or the base.
결론
Mack Bernard
회원 가입일: 03/08/16
597 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-4, Isaacson Spring 2016 UMass Dartmouth, Team 2-4, Isaacson Spring 2016 회원
UMASSD-ISAACSON-S16S2G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 820
