주요 콘텐츠로 건너뛰기
Hamilton Beach 70730 Motor Replacement
필요한 것
  1. Hamilton Beach 70730 Motor Replacement, Bowl: 1 단계, 이미지 1/1
    • Unscrew the cover by turning it counterclockwise.
  2. Hamilton Beach 70730 Motor Replacement: 2 단계, 이미지 1/1
    • Grab the scraper by the midsection to remove.
  3. Hamilton Beach 70730 Motor Replacement: 3 단계, 이미지 1/1
    • Carefully remove the blades by lifting them off of the blade shaft.
  4. Hamilton Beach 70730 Motor Replacement: 4 단계, 이미지 1/1
    • Rotate the bowl counterclockwise to release it from the base.
  5. Hamilton Beach 70730 Motor Replacement: 5 단계, 이미지 1/1
    • Make sure there is no food or grime along the outside of the bowl or the base.
  6. Hamilton Beach 70730 Motor Replacement, Switch: 6 단계, 이미지 1/1
    • Using a metal spudger, pry the switch from the front of the device.
  7. Hamilton Beach 70730 Motor Replacement, Drive Shaft: 7 단계, 이미지 1/1
    • Using the metal spudger, remove the four adhesive plastic covers that hide the screws.
    • These covers are adhered to the screws.
  8. Hamilton Beach 70730 Motor Replacement: 8 단계, 이미지 1/1
    • Remove any excess glue that is adhered to the screws with the precision tweezers.
  9. Hamilton Beach 70730 Motor Replacement: 9 단계, 이미지 1/1
    • Using a JIS #1 driver, remove the four 10 mm screws.
  10. Hamilton Beach 70730 Motor Replacement: 10 단계, 이미지 1/1
    • Lift the driveshaft off of the base.
  11. Hamilton Beach 70730 Motor Replacement, Motor: 11 단계, 이미지 1/1
    • Reach in and remove the set of 3 gears.
  12. Hamilton Beach 70730 Motor Replacement: 12 단계, 이미지 1/1
    • Remove the four 8 mm JIS #1 screws that were revealed after removing the set of gears.
    • There will be lubricant on the screws.
  13. Hamilton Beach 70730 Motor Replacement: 13 단계, 이미지 1/1
    • Flip the device over so the bottom is visible.
  14. Hamilton Beach 70730 Motor Replacement: 14 단계, 이미지 1/1
    • Using a JIS #1 screwdriver, remove each of the four suction cups that are attached to the bottom of the food processor.
  15. Hamilton Beach 70730 Motor Replacement: 15 단계, 이미지 1/1
    • Using a JIS #1 screwdriver, remove the four 12 mm screws on the bottom.
    • The screws are recessed about 3 mm inside of the device and may not be easily visible.
  16. Hamilton Beach 70730 Motor Replacement: 16 단계, 이미지 1/1
    • Remove the two 4 mm screws underneath the on/off switch with a JIS #1 screwdriver.
  17. Hamilton Beach 70730 Motor Replacement: 17 단계, 이미지 1/1
    • Pull the bottom plate away from the base.
  18. Hamilton Beach 70730 Motor Replacement: 18 단계, 이미지 1/1
    • Using a JIS # 1 screwdriver, remove the three screws on the white bracket.
  19. Hamilton Beach 70730 Motor Replacement: 19 단계, 이미지 1/1
    • Remove the white bracket and guide the wires away from their holders. Be careful not to dislodge the spring held inside the base.
    • Be careful not to dislodge the spring on the cylindrical white piece next to it.
  20. Hamilton Beach 70730 Motor Replacement: 20 단계, 이미지 1/1
    • The motor can now be removed from the inside of the food processor.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Mack Bernard
회원 가입일: 03/08/16
597 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-4, Isaacson Spring 2016 UMass Dartmouth, Team 2-4, Isaacson Spring 2016 회원
UMASSD-ISAACSON-S16S2G4
3 회원들
안내서 5개 작성하였습니다
댓글 5개
Thanks for the guide! I would never have thought to dig through the grease in the gearbox to find the 4 machine screws buried under there. Turns out that my motor is fine, but the thermal fuse strapped to the windings burned out. $5 fix for a $150 device!
Louis H - 답글
I didnt see any thermal fuse
Micah the Challenger -
On the bottom of the motor, connected to red lead, wrapped in white shielding
Fidel Cashflow - 답글
My Hamilton Beach food processor stopped working. So I ordered another bottom part(motor assembly) but t it will not come on either. Are they not interchangeable?
nelda lowe - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 14
30일 전: 36
전체 시간: 5,639
