주요 콘텐츠로 건너뛰기
Hamilton Beach 70740 Bowl Replacement
필요한 것
  1. Hamilton Beach 70740 Bowl Replacement, Bowl: 1 단계, 이미지 1/1
    • Be sure your device is powered off before beginning this replacement guide.
    • Turn the lid counterclockwise to unlock, then lift it straight up from the bowl.
  2. Hamilton Beach 70740 Bowl Replacement: 2 단계, 이미지 1/2 Hamilton Beach 70740 Bowl Replacement: 2 단계, 이미지 2/2
    • Reach into the bowl and grasp the plastic component housing the blades. Lift straight up to remove the blades from the device.
  3. Hamilton Beach 70740 Bowl Replacement: 3 단계, 이미지 1/2 Hamilton Beach 70740 Bowl Replacement: 3 단계, 이미지 2/2
    • Twist the bowl counterclockwise to unlock, and remove.
결론
Once the bowl is removed reverse steps from 3 to 1 to reassemble the Food Processor.
David Gedeon
회원 가입일: 09/17/15
806 평판
안내서 6개 작성하였습니다
IUPUI, Team 1-1, Baechle Fall 2015 IUPUI, Team 1-1, Baechle Fall 2015 회원
IUPUI-BAECHLE-F15S1G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 763
