주요 콘텐츠로 건너뛰기
Hamilton Beach 70740 Motor Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. 주의: 1-5 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Hamilton Beach 70740 Motor Replacement, Base Removal: 1 단계, 이미지 1/3 Hamilton Beach 70740 Motor Replacement, Base Removal: 1 단계, 이미지 2/3 Hamilton Beach 70740 Motor Replacement, Base Removal: 1 단계, 이미지 3/3
    • Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
  2. Hamilton Beach 70740 Motor Replacement: 2 단계, 이미지 1/2 Hamilton Beach 70740 Motor Replacement: 2 단계, 이미지 2/2
    • Use a spudger to remove the 4 rubber base pads located at the corners of the device.
  3. Hamilton Beach 70740 Motor Replacement: 3 단계, 이미지 1/1
    • Unscrew all 4 screws that are located beneath the pads with a screwdriver and remove the plastic grey base.
  4. Hamilton Beach 70740 Motor Replacement: 4 단계, 이미지 1/1
    • Remove the screws indicated with a screw driver.
  5. Hamilton Beach 70740 Motor Replacement: 5 단계, 이미지 1/1
    • Remove the two screws behind the knob with a screwdriver.
  6. Hamilton Beach 70740 Motor Replacement, Motor/Cord: 6 단계, 이미지 1/1
    • Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Apply pressure at the edge of the plastic cap circles. Apply stress elsewhere may damage the device.
    • Note that the plastic caps are glued
  7. Hamilton Beach 70740 Motor Replacement: 7 단계, 이미지 1/1
    • Remove the 4 screws located under the plastic caps with a screw driver.
  8. Hamilton Beach 70740 Motor Replacement: 8 단계, 이미지 1/2 Hamilton Beach 70740 Motor Replacement: 8 단계, 이미지 2/2
    • Lift and remove the plastic gears at the center of the device.
    • Remove any grease residue underneath the plastic gears.
  9. Hamilton Beach 70740 Motor Replacement: 9 단계, 이미지 1/2 Hamilton Beach 70740 Motor Replacement: 9 단계, 이미지 2/2
    • Remove the remaining screws to unhinge the motor located at the center of the device using a screw driver.
  10. Hamilton Beach 70740 Motor Replacement, Motor: 10 단계, 이미지 1/1
    • Remove to electrical cap to the positive terminal(black terminal), and undo the wiring.
  11. Hamilton Beach 70740 Motor Replacement: 11 단계, 이미지 1/1
    • Remove the electrical cap to the negative end(red wire), and undo the wiring. Once this is complete reconstruct the wiring with the new motor.
결론
다른 2명이 해당 안내서를 완성하였습니다.
David Gedeon
회원 가입일: 09/17/15
806 평판
안내서 6개 작성하였습니다
IUPUI, Team 1-1, Baechle Fall 2015 IUPUI, Team 1-1, Baechle Fall 2015 회원
IUPUI-BAECHLE-F15S1G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 649
