소개
This procedure requires a moderate level of electrical wiring experience, and a few listed tools.
필요한 것
1 단계 Base Removal
주의: 1-5 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
다른 한 분이 해당 안내서를 완성하였습니다.
