주요 콘텐츠로 건너뛰기
Hamilton Beach Food Processor 70740 Motor/Cord Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. 주의: 1-5 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Hamilton Beach Food Processor 70740 Motor/Cord Replacement, Base Removal: 1 단계, 이미지 1/3 Hamilton Beach Food Processor 70740 Motor/Cord Replacement, Base Removal: 1 단계, 이미지 2/3 Hamilton Beach Food Processor 70740 Motor/Cord Replacement, Base Removal: 1 단계, 이미지 3/3
    • Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
  2. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 2 단계, 이미지 1/2 Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 2 단계, 이미지 2/2
    • Use a spudger to remove the 4 rubber base pads located at the corners of the device.
  3. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 3 단계, 이미지 1/1
    • Unscrew all 4 screws that are located beneath the pads with a screwdriver and remove the plastic grey base.
  4. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 4 단계, 이미지 1/1
    • Remove the screws indicated with a screw driver.
  5. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 5 단계, 이미지 1/1
    • Remove the two screws behind the knob with a screwdriver.
  6. Hamilton Beach Food Processor 70740 Motor/Cord Replacement, Motor/Cord: 6 단계, 이미지 1/1
    • Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Apply pressure at the edge of the plastic cap circles. Apply stress elsewhere may damage the device.
    • Note that the plastic caps are glued
  7. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 7 단계, 이미지 1/1
    • Remove the 4 screws located under the plastic caps with a screw driver.
  8. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 8 단계, 이미지 1/2 Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 8 단계, 이미지 2/2
    • Lift and remove the plastic gears at the center of the device.
    • Remove any grease residue underneath the plastic gears.
  9. Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 9 단계, 이미지 1/2 Hamilton Beach Food Processor 70740 Motor/Cord Replacement: 9 단계, 이미지 2/2
    • Remove the remaining screws to unhinge the motor located at the center of the device using a screw driver.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David Gedeon
회원 가입일: 09/17/15
806 평판
안내서 6개 작성하였습니다
IUPUI, Team 1-1, Baechle Fall 2015 IUPUI, Team 1-1, Baechle Fall 2015 회원
IUPUI-BAECHLE-F15S1G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 217
