Shower heads must be replaced every 6-8 months to avoid sediment buildup and ensure efficient water flow.
As such, this guide aims to explain how to replace a handheld showerhead where any model is applicable in the procedural steps that follow.
Prior to following this guide, it is important to understand the slight risk of injury with this repair in terms of wet surfaces. Overall, this procedure involves little to no possibility for injury but caution should be advised and shoes with good traction can be utilized to avoid slipping while performing the replacement.
It is also important to note that water should be turned off before following the procedure outlined below.
Modern shower heads and arms are usually compatible with any shower located in the US and Canada. Restrictions may include antique (older than 1994) and other uncommon showers.
Unpack the new showerhead. Take note of the type of attachment and what tool you might need to tighten it.
Be sure to check with the included manual whether or not you will need thread seal tape, as some showers do not require it.
If you need to use Thread Seal Tape, make sure to wrap it with the direction of the threading, so it stays smooth and aligned as you thread the ends together.
Attach the ball jointed segment to the attaching nut, with the nut’s threaded end towards the shower head, facing away from where the ball component was screwed onto the pipe.
Ensure that the rubber or plastic washer is in place to prevent leaks in the future.
Finish tightening all components properly with your wrench (do not over-tighten).
Tighten down the nut encasing the ball-jointed segment until it will not move or slip on its own, but is loose enough to be gently adjusted with minimal force. This component will most likely not require the wrench, as it is built to be adjusted.
Run the water through the showerhead to test for leaks, and tighten or loosen components as necessary.
Ensure the ball joint pivots easily in the socket. If it does not, loosen the nut around the ball until it can move (without adjusting the other components).
