주요 콘텐츠로 건너뛰기
Handheld Toilet Bidet Sprayer Replacement
필요한 것
  1. Handheld Toilet Bidet Sprayer Replacement, Handheld Toilet Bidet Sprayer: 1 단계, 이미지 1/1
    • Turn off the toilet water valve by turning the knob clockwise.
  2. Handheld Toilet Bidet Sprayer Replacement: 2 단계, 이미지 1/1
    • Flush the toilet until no water is left in the tank.
  3. Handheld Toilet Bidet Sprayer Replacement: 3 단계, 이미지 1/1
    • Place a towel under the tank incase of any water drops.
  4. Handheld Toilet Bidet Sprayer Replacement: 4 단계, 이미지 1/1
    • Unscrew the water supply line from the T-connector by turning the knob counterclockwise.
  5. Handheld Toilet Bidet Sprayer Replacement: 5 단계, 이미지 1/1
    • Unscrew the hose from the T-connector by turning the knob counterclockwise.
  6. Handheld Toilet Bidet Sprayer Replacement: 6 단계, 이미지 1/1
    • Unscrew the T-connector from the toilet by turning the knob counterclockwise.
  7. Handheld Toilet Bidet Sprayer Replacement: 7 단계, 이미지 1/3 Handheld Toilet Bidet Sprayer Replacement: 7 단계, 이미지 2/3 Handheld Toilet Bidet Sprayer Replacement: 7 단계, 이미지 3/3
    • Install the toilet sprayer's rubber on the water supply hose from the side that is causing a water leak. This will stop water leaking from the hose.
  8. Handheld Toilet Bidet Sprayer Replacement: 8 단계, 이미지 1/1
    • Screw the T-connector back on the toilet by turning the knob clockwise.
    • Be careful not to cross the threads.
  9. Handheld Toilet Bidet Sprayer Replacement: 9 단계, 이미지 1/1
    • Screw the water supply nut onto the bottom of the T-connector by turning the knob clockwise. Make sure it is firmly hand tight.
  10. Handheld Toilet Bidet Sprayer Replacement: 10 단계, 이미지 1/1
    • Screw the water supply hose back on the T-connector by turning the knob clockwise. Be sure not to over tighten the nut.
  11. Handheld Toilet Bidet Sprayer Replacement: 11 단계, 이미지 1/1
    • Turn on the toilet water valve by turning the knob counterclockwise. now, you can test your water and spray it through the hose. Make sure there is no water leaking.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Almuhannad Althurwi
회원 가입일: 06/29/18
201 평판
안내서 1개 작성함
댓글 2개
If this is used as a bidet, wouldn’t the water be awfully cold? Almost too invigorating. If just used to help clean the toilet, okay.
Pete
Pete Chisteckoff - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 21
30일 전: 111
전체 시간: 9,932
