소개
The handheld toilet bidet sprayer is a simple but effective cleaning product. It is most common in the Middle East. It is important to know how to replace or fix one of them. People can replace or fix the handheld toilet bidet Sprayer when there is water leaking from the pipes. This is the most common reason to fix the handheld toilet bidet sprayer. If you need to replace a damaged or nonworking handheld toilet bidet sprayer, this guide will offer step by step instructions with visuals to help you.
필요한 것
Turn off the toilet water valve by turning the knob clockwise.
다른 2명이 해당 안내서를 완성하였습니다.
2가이드 댓글
If this is used as a bidet, wouldn’t the water be awfully cold? Almost too invigorating. If just used to help clean the toilet, okay.
Pete
Same concern.
