소개
The handheld toilet bidet sprayer is a simple but effective cleaning product. It is most common in the Middle East. It is important to know how to replace or fix one of them. People can replace or fix the handheld toilet bidet Sprayer when there is water leaking from the pipes. This is the most common reason to fix the handheld toilet bidet sprayer. If you need to replace a damaged or nonworking handheld toilet bidet sprayer, this guide will offer step by step instructions with visuals to help you.
필요한 것
Turn off the toilet water valve by turning the knob clockwise.
Turn on the toilet water valve by turning the knob counterclockwise. now, you can test your water and spray it through the hose. Make sure there is no water leaking.
Hi,
I have installed a handheld bidet like shown and having issues with pressure coming out of the handheld sprayer.
The water pressure that comes out of the handheld sprayer is very low , but if I flush the toilet, while the cistern is refilling the pressure and sprayer works fine. As soon as the cistern is full the pressure drops and the and sprayer stops working. Thoughts?
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
If this is used as a bidet, wouldn’t the water be awfully cold? Almost too invigorating. If just used to help clean the toilet, okay.
Pete
Same concern.
