주요 콘텐츠로 건너뛰기
Handspring Visor Deluxe PDA Back Cover Replacement
필요한 것
  1. Handspring Visor Deluxe PDA Back Cover Replacement, Outside cover and stylus: 1 단계, 이미지 2개 중 1개 Handspring Visor Deluxe PDA Back Cover Replacement, Outside cover and stylus: 1 단계, 이미지 2개 중 2개
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Back Cover Replacement: 2 단계, 이미지 3개 중 1개 Handspring Visor Deluxe PDA Back Cover Replacement: 2 단계, 이미지 3개 중 2개 Handspring Visor Deluxe PDA Back Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Back Cover Replacement: 3 단계, 이미지 3개 중 1개 Handspring Visor Deluxe PDA Back Cover Replacement: 3 단계, 이미지 3개 중 2개 Handspring Visor Deluxe PDA Back Cover Replacement: 3 단계, 이미지 3개 중 3개
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Back Cover Replacement, Batteries: 4 단계, 이미지 2개 중 1개 Handspring Visor Deluxe PDA Back Cover Replacement, Batteries: 4 단계, 이미지 2개 중 2개
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Back Cover Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Back Cover Replacement, Back Cover: 6 단계, 이미지 1개 중 1개
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Back Cover Replacement: 7 단계, 이미지 3개 중 1개 Handspring Visor Deluxe PDA Back Cover Replacement: 7 단계, 이미지 3개 중 2개 Handspring Visor Deluxe PDA Back Cover Replacement: 7 단계, 이미지 3개 중 3개
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Back Cover Replacement: 8 단계, 이미지 3개 중 1개 Handspring Visor Deluxe PDA Back Cover Replacement: 8 단계, 이미지 3개 중 2개 Handspring Visor Deluxe PDA Back Cover Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Disconnect the flex strip from the motherboard with tweezers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Robert
회원 가입일: 07/07/12
23 평판
안내서 1개를 작성함
Cal Poly, Team 1-2, Regan SU 2012 Cal Poly, Team 1-2, Regan SU 2012 회원
CPSU-REGAN-SU12S1G2
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 738
