주요 콘텐츠로 건너뛰기
Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement
필요한 것
  1. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Outside cover and stylus: 1 단계, 이미지 1/2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Outside cover and stylus: 1 단계, 이미지 2/2
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 2 단계, 이미지 1/3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 2 단계, 이미지 2/3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 2 단계, 이미지 3/3
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 3 단계, 이미지 1/3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 3 단계, 이미지 2/3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 3 단계, 이미지 3/3
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Batteries: 4 단계, 이미지 1/2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Batteries: 4 단계, 이미지 2/2
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 5 단계, 이미지 1/1
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Back Cover: 6 단계, 이미지 1/1
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 7 단계, 이미지 1/3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 7 단계, 이미지 2/3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 7 단계, 이미지 3/3
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 8 단계, 이미지 1/3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 8 단계, 이미지 2/3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 8 단계, 이미지 3/3
    • Disconnect the flex strip from the motherboard with tweezers.
  9. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Button Pad and Battery Terminal: 9 단계, 이미지 1/1
    • Use tweezers to remove the power button from the back case.
  10. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 10 단계, 이미지 1/3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 10 단계, 이미지 2/3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 10 단계, 이미지 3/3
    • Disconnect the button pad by using the spudger to pry it off the motherboard.
    • Remove the button pad.
  11. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Motherboard and Memory card I/O: 11 단계, 이미지 1/2 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement, Motherboard and Memory card I/O: 11 단계, 이미지 2/2
    • Unscrew the two 2.94mm Phillips #00 screws that hold the motherboard in place.
  12. Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 12 단계, 이미지 1/3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 12 단계, 이미지 2/3 Handspring Visor Deluxe PDA Motherboard and Memory card I/O Replacement: 12 단계, 이미지 3/3
    • Use the spudger to lift the motherboard from the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David Faltemier
회원 가입일: 06/20/12
19 평판
안내서 5개 작성하였습니다
Cal Poly, Team 1-2, Regan SU 2012 Cal Poly, Team 1-2, Regan SU 2012 회원
CPSU-REGAN-SU12S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 1,057
