소개
This guide will show you how to take off the front cover, stylus, and memory card cover.
  1. Remove the outer screen cover by releasing  the top clip from the main body of the device. Remove the outer screen cover by releasing  the top clip from the main body of the device.
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Pull out the stylus from the top right corner of the device. Pull out the stylus from the top right corner of the device. Pull out the stylus from the top right corner of the device.
    • Pull out the stylus from the top right corner of the device.
  4. Slide the memory cartridge cover up and off the device. Slide the memory cartridge cover up and off the device. Slide the memory cartridge cover up and off the device.
    • Slide the memory cartridge cover up and off the device.
결론
David Faltemier
회원 가입일: 2012년 06월 20일
19 평판
안내서 5개 작성하였습니다
Cal Poly, Team 1-2, Regan SU 2012 Cal Poly, Team 1-2, Regan SU 2012 회원
CPSU-REGAN-SU12S1G2
4 회원들
안내서 6개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 284
