주요 콘텐츠로 건너뛰기
Handspring Visor Edge Battery Replacement
필요한 것
  1. Handspring Visor Edge Battery Replacement, Flip Cover: 1 단계, 이미지 2개 중 1개 Handspring Visor Edge Battery Replacement, Flip Cover: 1 단계, 이미지 2개 중 2개
    • Open the Visor Edge placing the screen and the inner part of the flip cover face down on a flat surface such as a table
    • On the back of the PDA there is a tab connecting the flip cover to the device. Push gently on this tab trying to slide the cover upwards along the surface then lift the pieces apart to fully detach them
    • Do not pull or tug on the flip cover in an attempt to remove it from the PDA this can result in the cover snapping causing damage to the device
    • To reassemble push the downward on the flip cover where there is an indent on the PDA indicating where the pieces connect. Finally, push the cover until it snaps into place.
  2. Handspring Visor Edge Battery Replacement, Back Panel: 2 단계, 이미지 1개 중 1개
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Battery Replacement: 4 단계, 이미지 2개 중 1개 Handspring Visor Edge Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Battery Replacement: 5 단계, 이미지 2개 중 1개 Handspring Visor Edge Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Battery Replacement, Battery: 7 단계, 이미지 1개 중 1개
    • Gently pull off the front cover.
  8. Handspring Visor Edge Battery Replacement: 8 단계, 이미지 2개 중 1개 Handspring Visor Edge Battery Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Gently use your finger or tweezers to push the brown lock away from the side of the circuit board that is holding the ribbon cable.
    • Remove the ribbon cable with tweezers.
  9. Handspring Visor Edge Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Using the tweezers, pull back the ribbon cable on the top of the device.
    • Pull at the white part of the ribbon to avoid tearing.
  10. Handspring Visor Edge Battery Replacement: 10 단계, 이미지 1개 중 1개
    • Using the same technique as with the other ribbons, locate and disconnect the ribbon cable above the battery pack.
  11. Handspring Visor Edge Battery Replacement: 11 단계, 이미지 1개 중 1개
    • All the ribbon cables should be disconnected from the mother board.
    • Remove the four 3.6 mm Phillips #00 screws located at each corner of the device.
  12. Handspring Visor Edge Battery Replacement: 12 단계, 이미지 2개 중 1개 Handspring Visor Edge Battery Replacement: 12 단계, 이미지 2개 중 2개
    • Carefully separate the circuit board and the screen. (Be careful of soldered wires when separating)
    • Be careful not to break the soldered wires that connects the circuit board to the battery pack.
    • Disconnect the wire that connects the battery pack to the motherboard using tweezers.
  13. Handspring Visor Edge Battery Replacement: 13 단계, 이미지 2개 중 1개 Handspring Visor Edge Battery Replacement: 13 단계, 이미지 2개 중 2개
    • Wedge the spudger under the battery to pry it apart from the adhesive.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Christian Valoria
회원 가입일: 01/23/11
229 평판
안내서 2개를 작성함
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 회원
CPSU-MANESS-W11S11G28
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 9
지난 30일: 32
전체 시간: 3,568
