주요 콘텐츠로 건너뛰기
Handspring Visor Edge Screen Replacement
필요한 것
  1. Handspring Visor Edge Screen Replacement, Flip Cover: 1 단계, 이미지 2개 중 1개 Handspring Visor Edge Screen Replacement, Flip Cover: 1 단계, 이미지 2개 중 2개
    • Open the Visor Edge placing the screen and the inner part of the flip cover face down on a flat surface such as a table
    • On the back of the PDA there is a tab connecting the flip cover to the device. Push gently on this tab trying to slide the cover upwards along the surface then lift the pieces apart to fully detach them
    • Do not pull or tug on the flip cover in an attempt to remove it from the PDA this can result in the cover snapping causing damage to the device
    • To reassemble push the downward on the flip cover where there is an indent on the PDA indicating where the pieces connect. Finally, push the cover until it snaps into place.
  2. Handspring Visor Edge Screen Replacement, Back Panel: 2 단계, 이미지 1개 중 1개
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Screen Replacement: 4 단계, 이미지 2개 중 1개 Handspring Visor Edge Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Screen Replacement: 5 단계, 이미지 2개 중 1개 Handspring Visor Edge Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Screen Replacement, Screen: 7 단계, 이미지 1개 중 1개
    • Place the PDA front face up.
    • Gently pull off the front cover.
  8. Handspring Visor Edge Screen Replacement: 8 단계, 이미지 2개 중 1개 Handspring Visor Edge Screen Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Flip over the PDA.
    • Use the tweezers to remove the ribbon cable attaching the screen to the circuit board.
  9. Handspring Visor Edge Screen Replacement: 9 단계, 이미지 2개 중 1개 Handspring Visor Edge Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Wedge the spudger in between the glass and the metal frame.
    • Slide the spudger down the length of the screen to detach from the frame.
    • With your hands, pry the screen up from the detached side. The screen will pop off.
결론
작성자
8다른 기여자 명과 함께
Christian Valoria
회원 가입일: 01/23/11
229 평판
안내서 2개를 작성함
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 회원
CPSU-MANESS-W11S11G28
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 16
전체 시간: 1,745
