주요 콘텐츠로 건너뛰기
Handspring Visor Edge Screen Replacement
필요한 것
  1. Handspring Visor Edge Screen Replacement, Flip Cover: 1 단계, 이미지 1/2 Handspring Visor Edge Screen Replacement, Flip Cover: 1 단계, 이미지 2/2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Screen Replacement, Back Panel: 2 단계, 이미지 1/1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Screen Replacement: 3 단계, 이미지 1/1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Screen Replacement: 4 단계, 이미지 1/2 Handspring Visor Edge Screen Replacement: 4 단계, 이미지 2/2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Screen Replacement: 5 단계, 이미지 1/2 Handspring Visor Edge Screen Replacement: 5 단계, 이미지 2/2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Screen Replacement: 6 단계, 이미지 1/1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Screen Replacement, Screen: 7 단계, 이미지 1/1
    • Place the PDA front face up.
    • Gently pull off the front cover.
  8. Handspring Visor Edge Screen Replacement: 8 단계, 이미지 1/2 Handspring Visor Edge Screen Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Flip over the PDA.
    • Use the tweezers to remove the ribbon cable attaching the screen to the circuit board.
  9. Handspring Visor Edge Screen Replacement: 9 단계, 이미지 1/2 Handspring Visor Edge Screen Replacement: 9 단계, 이미지 2/2
    • Wedge the spudger in between the glass and the metal frame.
    • Slide the spudger down the length of the screen to detach from the frame.
    • With your hands, pry the screen up from the detached side. The screen will pop off.
결론
Christian Valoria
회원 가입일: 01/23/11
201 평판
안내서 2개 작성하였습니다
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 회원
CPSU-MANESS-W11S11G28
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 18
전체 시간: 1,564
