주요 콘텐츠로 건너뛰기
Handspring Visor Edge Speaker Replacement
필요한 것
  1. Handspring Visor Edge Speaker Replacement, Flip Cover: 1 단계, 이미지 1/2 Handspring Visor Edge Speaker Replacement, Flip Cover: 1 단계, 이미지 2/2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Speaker Replacement, Back Panel: 2 단계, 이미지 1/1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Speaker Replacement: 3 단계, 이미지 1/1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Speaker Replacement: 4 단계, 이미지 1/2 Handspring Visor Edge Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Speaker Replacement: 5 단계, 이미지 1/2 Handspring Visor Edge Speaker Replacement: 5 단계, 이미지 2/2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Speaker Replacement: 6 단계, 이미지 1/1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Speaker Replacement, Speaker: 7 단계, 이미지 1/1
    • Gently pull off front cover.
  8. Handspring Visor Edge Speaker Replacement: 8 단계, 이미지 1/1
    • Gently remove buttons by hand.
  9. Handspring Visor Edge Speaker Replacement: 9 단계, 이미지 1/1
    • Pull off button board.
    • (The button board is located underneath the buttons).
  10. Handspring Visor Edge Speaker Replacement: 10 단계, 이미지 1/1
    • Carefully remove the speaker by pulling on the body of the plug with a pair of tweezers, rocking it from side to side to ease it if necessary.
    • Pull in the same direction as the individual wires are running and make sure to evenly on the full width of the cable so that no individual wires are overly strained.
결론
Nick Lazarakis
회원 가입일: 01/23/11
331 평판
안내서 3개 작성하였습니다
Cal Poly, Team 11-28, Maness Winter 2011 Cal Poly, Team 11-28, Maness Winter 2011 회원
CPSU-MANESS-W11S11G28
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 792
