주요 콘텐츠로 건너뛰기
Hannspree Hannspad SN1AT71 Back Panel Replacement
필요한 것
  1. Hannspree Hannspad SN1AT71 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Back Panel Replacement: 2 단계, 이미지 1/2 Hannspree Hannspad SN1AT71 Back Panel Replacement: 2 단계, 이미지 2/2
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Back Panel Replacement: 3 단계, 이미지 1/1
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Back Panel Replacement: 4 단계, 이미지 1/2 Hannspree Hannspad SN1AT71 Back Panel Replacement: 4 단계, 이미지 2/2
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Back Panel Replacement: 5 단계, 이미지 1/2 Hannspree Hannspad SN1AT71 Back Panel Replacement: 5 단계, 이미지 2/2
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
결론
다른 4명이 해당 안내서를 완성하였습니다.
matthew vandeventer
회원 가입일: 03/11/15
950 평판
안내서 5개 작성하였습니다
Colorado Springs, Team 9-4, Panko Spring 2015 Colorado Springs, Team 9-4, Panko Spring 2015 회원
UCCS-PANKO-S15S9G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 2,401
