주요 콘텐츠로 건너뛰기
Hannspree SN12E2 Fan/Motherboard Replacement
필요한 것
  1. Hannspree SN12E2 Fan/Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 Fan/Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 Fan/Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Hannspree SN12E2 Fan/Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Hannspree SN12E2 Fan/Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 Fan/Motherboard Replacement, Touchpad Plane/Keyboard: 4 단계, 이미지 1개 중 1개
    • Remove all the 5mm PH0 screws on the back cover
  5. Hannspree SN12E2 Fan/Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Hannspree SN12E2 Fan/Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Hannspree SN12E2 Fan/Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Gently pry the case apart starting at the lower right corner using the small spudger
    • Move around the case gently prying until the touchpad plane is free from the rest of the case
  6. Hannspree SN12E2 Fan/Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Hannspree SN12E2 Fan/Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Gently lift up on the touchpad portion of the touchpad plane
    • Unplug the ZIFF connector by pulling gently on the black retaining blade and removing the white flat flex cable
    • Pull the touchpad away from the rest of the case
  7. Hannspree SN12E2 Fan/Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Gently lift up on the loose keyboard to expose the ZIFF connector.
    • Unplug the keyboard ZIFF following the same instructions as the touchpad ZIFF
  8. Hannspree SN12E2 Fan/Motherboard Replacement, Fan/Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove 3.4mm PH0 retaining screws as well as the three 3mm PH0 fan screws
  9. Hannspree SN12E2 Fan/Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Hannspree SN12E2 Fan/Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Unplug all pictured connectors
  10. Hannspree SN12E2 Fan/Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Hannspree SN12E2 Fan/Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the motherboard from the housing place it on a flat surface.
    • Flip over the motherboard so that the heat pipes ae face up.and disconnect fan JST Connector, pictured in red
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brianna Johnson
회원 가입일: 03/21/19
443 평판
안내서 3개를 작성함
UMass Dartmouth, Team S2-G2, Simcock Spring 2019 UMass Dartmouth, Team S2-G2, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S2G2
4 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 13
전체 시간: 539
