주요 콘텐츠로 건너뛰기
Hannspree SN12E2 Speaker Replacement
필요한 것
  1. Hannspree SN12E2 Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 Speaker Replacement: 3 단계, 이미지 3개 중 1개 Hannspree SN12E2 Speaker Replacement: 3 단계, 이미지 3개 중 2개 Hannspree SN12E2 Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 Speaker Replacement, Touchpad Plane/Keyboard: 4 단계, 이미지 1개 중 1개
    • Remove all the 5mm PH0 screws on the back cover
  5. Hannspree SN12E2 Speaker Replacement: 5 단계, 이미지 3개 중 1개 Hannspree SN12E2 Speaker Replacement: 5 단계, 이미지 3개 중 2개 Hannspree SN12E2 Speaker Replacement: 5 단계, 이미지 3개 중 3개
    • Gently pry the case apart starting at the lower right corner using the small spudger
    • Move around the case gently prying until the touchpad plane is free from the rest of the case
  6. Hannspree SN12E2 Speaker Replacement: 6 단계, 이미지 2개 중 1개 Hannspree SN12E2 Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Gently lift up on the touchpad portion of the touchpad plane
    • Unplug the ZIFF connector by pulling gently on the black retaining blade and removing the white flat flex cable
    • Pull the touchpad away from the rest of the case
  7. Hannspree SN12E2 Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Gently lift up on the loose keyboard to expose the ZIFF connector.
    • Unplug the keyboard ZIFF following the same instructions as the touchpad ZIFF
  8. Hannspree SN12E2 Speaker Replacement, Speaker: 8 단계, 이미지 2개 중 1개 Hannspree SN12E2 Speaker Replacement, Speaker: 8 단계, 이미지 2개 중 2개
    • Remove the two screws on the speakers.
  9. Hannspree SN12E2 Speaker Replacement: 9 단계, 이미지 1개 중 1개
    • Gently remove the JST connector by pulling parallel to the housing .
    • When replacing the connectors ensure that they are oriented correctly. The housing is keyed to prevent the connectors from being plugged in backwards.
  10. Hannspree SN12E2 Speaker Replacement: 10 단계, 이미지 1개 중 1개
    • Repeat same steps for other speaker if necessary.
결론
작성자
4다른 기여자 명과 함께
Tim Chase
회원 가입일: 03/25/19
363 평판
안내서 3개를 작성함
UMass Dartmouth, Team S2-G2, Simcock Spring 2019 UMass Dartmouth, Team S2-G2, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S2G2
4 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 7
전체 시간: 219
