주요 콘텐츠로 건너뛰기
Hard / Factory Reset
동영상 개요
  1. Hard / Factory Reset, Hard Reset - Method One:: 1 단계, 이미지 1/3 Hard / Factory Reset, Hard Reset - Method One:: 1 단계, 이미지 2/3 Hard / Factory Reset, Hard Reset - Method One:: 1 단계, 이미지 3/3
    • Switch off the phone.
    • Pres the Power button and when you feel a vibration release it and press and hold the Volume Up button.
    • From Boot mode menu select [Recovery mode] (use Volume Up for navigation and volume doun for OK).
    • Now you are in the known Android System recovery menu. Use again the Volume Up for navigation and the Volume Down for OK and select one by one: wipe data/factory reset - Yes -- delete all user data - reboot system now.
    • Tis will reboot the device and will restore to its default settings.
  2. Hard / Factory Reset, Factory Reset - Method Two: 2 단계, 이미지 1/3 Hard / Factory Reset, Factory Reset - Method Two: 2 단계, 이미지 2/3 Hard / Factory Reset, Factory Reset - Method Two: 2 단계, 이미지 3/3
    • Press the Power button and wen you fill the vibration, release the Power button and press and hold the Volume Down button.
    • Now the device is in Factory mode. Use the Volume Up/Down buttons for movement and the Power button for OK and select Clear eMMC.
    • That's all. The phone will reboot and will be restored to a factory settings.
    • Did you do it successfully?
결론
다른 24명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,278 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,532개 작성하였습니다
댓글 22개
great simple clear instructions - did exactly what you said - phone back up and running good as new! Thanks. M
Marty - 답글
Thanks. The phone has reset.
melandart - 답글
“eMMC is busy can't format, please retry”
What do we do?
richterrea - 답글
Today I also met this message. How did you solve this problem? Thanks, Zoltan (HUN)
Zoltán Bocskai -
HI!, I did the “clear eMMc” method but still my MePop_V03 phone still stock on logo screen.
what should I do?
Please help me .thanks in advance God bless
Herbert Redondo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 59
30일 전: 326
전체 시간: 48,057
