주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hard Drive
필요한 것
  1. Hard Drive, Battery: 1 단계, 이미지 1개 중 1개
    • Before proceeding, power down your Laptop and remove the power cable.
    • Close the display and lay it on a flat surface, top-side down.
  2. Hard Drive: 2 단계, 이미지 1개 중 1개
    • Unlock the battery by sliding the battery lock to the unlock part.
  3. Hard Drive: 3 단계, 이미지 1개 중 1개
    • Slide the middle lock to the right and the battery will pop up.
  4. Hard Drive: 4 단계, 이미지 1개 중 1개
    • If you want to replace the battery and nothing else then now is the time to do so.
    • Once the battery hatch is unlocked you can now safely remove the battery.
  5. Hard Drive, Hard Drive: 5 단계, 이미지 1개 중 1개
    • Use a Philips J1 driver to remove two screws securing the hard drive cover.
  6. Hard Drive: 6 단계, 이미지 1개 중 1개
    • If the hard drive is not located here, then it will be located in the next step.
    • Now you can remove, replace or upgrade the hard drive to an SSD if you need to.
  7. Hard Drive: 7 단계, 이미지 1개 중 1개
    • If your hard drive was not located in the previous spot or you have two drives then this one is located here.
    • Use a Philips J1 driver to remove eight screws securing the bottom case.
  8. Hard Drive: 8 단계, 이미지 1개 중 1개
    • After removing the bottom panel cover, then you should spot the hard drive right here.
  9. Hard Drive: 9 단계, 이미지 2개 중 1개 Hard Drive: 9 단계, 이미지 2개 중 2개
    • While removing the hard drive, try to be gentle.
    • Now you can simply upgrade, replace or remove the hard drive right here. To remove it, push it from the two corners and it should come off like in the next picture.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Regome
회원 가입일: 01/20/23
794 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 232
