주요 콘텐츠로 건너뛰기
Hard Reset
  1. Hard Reset, Hard Reset: 1 단계, 이미지 1/1
    • With the phone powered off, press and hold the Talk/Send, End, and Power buttons (the 3 circled here) for about 3 seconds.
  2. Hard Reset: 2 단계, 이미지 1/2 Hard Reset: 2 단계, 이미지 2/2
    • When the screen powers on, you will see an instructional message.
    • Press the volume up button to perform the hard reset.
    • The hard reset will erase all personal data on your device. If you would like to cancel the hard reset, press any other button.
  3. Hard Reset: 3 단계, 이미지 1/1
    • Your device will display this screen after a few seconds. Press the Volume Up button to boot your phone.
  4. Hard Reset: 4 단계, 이미지 1/2 Hard Reset: 4 단계, 이미지 2/2
    • Your phone will display this screen. If you would like to import your SIM contacts now, tap "Import SIM contacts" and tap "Next". Otherwise, tap "Cancel".
결론
You have just performed a hard reset on your HTC Fortress. All personal data on your phone has been deleted, and your phone is now back to its default settings.
다른 7명이 해당 안내서를 완성하였습니다.
Lucas David
회원 가입일: 04/19/13
540 평판
안내서 9개 작성하였습니다
Cal Poly, Team 4-13, Maness Spring 2013 Cal Poly, Team 4-13, Maness Spring 2013 회원
CPSU-MANESS-S13S4G13
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
great information thanks.
regards
Jrubio - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 2,510
