주요 콘텐츠로 건너뛰기
Harley-Davidson Fatboy Lo Battery Replacement
필요한 것
  1. Harley-Davidson Fatboy Lo Battery Replacement, Battery: 1 단계, 이미지 1/2 Harley-Davidson Fatboy Lo Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the screw using the flathead screwdriver.
    • Following removal of the screw, lift the seat from the rear and then carefully pull the seat towards the back of the bike removing it.
  2. Harley-Davidson Fatboy Lo Battery Replacement: 2 단계, 이미지 1/1
    • The battery is located at the center of the frame, directly beneath the seat.
  3. Harley-Davidson Fatboy Lo Battery Replacement: 3 단계, 이미지 1/2 Harley-Davidson Fatboy Lo Battery Replacement: 3 단계, 이미지 2/2
    • To disconnect the terminals you will use a ratchet and 10mm socket to remove the bolts, then remove the wires from each terminal.
    • Be sure to disconnect the ground before the positive connection. (Note: the positive is covered by a red plastic cover, this must be removed to expose the terminal.)
  4. Harley-Davidson Fatboy Lo Battery Replacement: 4 단계, 이미지 1/1
    • Once the wires are disconnected from the terminals carefully remove the battery, by grasping the battery and gently lifting from its base.
  5. Harley-Davidson Fatboy Lo Battery Replacement: 5 단계, 이미지 1/1
    • Ensure that the positive terminal is on the left side of the bike and the negative terminal is on the right.
    • Gently place the battery back onto the base avoiding any wires.
  6. Harley-Davidson Fatboy Lo Battery Replacement: 6 단계, 이미지 1/2 Harley-Davidson Fatboy Lo Battery Replacement: 6 단계, 이미지 2/2
    • Reconnect the terminals by placing the wires over the designated terminals.
    • Positive before Ground.
    • Once the wires are in place tighten the screws back in place using the ratchet wrench and 10mm socket.
  7. Harley-Davidson Fatboy Lo Battery Replacement: 7 단계, 이미지 1/1
    • Cover the positive terminal with the red plastic covering provided.
  8. Harley-Davidson Fatboy Lo Battery Replacement: 8 단계, 이미지 1/2 Harley-Davidson Fatboy Lo Battery Replacement: 8 단계, 이미지 2/2
    • To replace the seat, place the metal tab, on the bottom side at the front of the seat into the slot at the base of the fuel tank.
    • Ensuring the tab is in place, repeat step 1 in reverse to reinstall the seat.
결론
This is a comprehensive guide that walks through the removal of the old battery to the installation of the new.
Austin Stone
회원 가입일: 03/31/20
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 24
30일 전: 113
전체 시간: 9,937
