소개
This guide will show you how to remove the old front brake pads and then install new ones.
Brake pads should be changed at the owner's discretion. Most brake pads will make a squeaking or scraping noise when they are approaching the end of their life.
필요한 것
For the best access to the brake pads, we recommend securing the motorcycle in an upright position.
If you do not have a motorcycle lift, you will still be able change the brake pads, but it is still a good idea to secure the front wheel in place.
Using a 1/4" hex head or allen wrench, unscrew the two bolts holding the front brake assembly to the fork.
Unscrew and remove the bottom bolt, but do not completely remove the top bolt yet.
Using a Phillips #2 screwdriver, remove the two screws securing the cover on the master brake-fluid reservoir.
Carefully remove the cover of the master reservoir, making sure that you do not spill any of the brake fluid.
Many 90’s Harleys use DOT5, which doesn’t scar the paint like DOT3/4/5.1 will. The reservoir will have a label telling you which type of brake fluid to use.
Position the screw of a large C clamp so that the head of the screw is pressing against the inside of the brake piston.
It is possible to use your hands rather than a C clamp, but it is much more difficult.
Slowly tighten the C clamp, forcing the brake piston back into the brake cylinder until it is completely depressed.
Inspect the new brake pads for chips or other signs of wear.
Apply a moderate amount of anti-squeal compound to the back of each new brake pad.
Using your fingers, pull the alignment peg out of its hole in the stationary caliper.
Apply a thin layer of grease to the alignment peg.
Re-install the alignment peg, but do not push it all the way in. Only push it in about half-way.
The spring should be on the same side as the alignment peg.
Place one of the brake pads into the floating caliper, with the anti-squeal side facing away from the spring and mount peg.
Before taking the motorcycle up to full speed on the open road, test that the brakes work by starting and stopping at low speeds in an empty street or parking lot.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 9개
Nice job. Was looking for a picture of that darn anti vibration clip. Thanks
Blake Will - 답글
The spring clip is installed wrong. The brake pad will rattle. Push the brake pad in from the rotor side with the clip pushing down hard on the pad holding it in the housing. The clip is to stop the pad from rattling in the housing, not to hold it against the piston.
Frank Lock - 답글
GOOD JOB !!! This is almost the same exact as my 98 road king brakes.
Brett Hartt: this is so valuable for simple latin american like me. A professional tool that you are giving away. G. bless your generations forever.
Manu Costa - 답글
I think Brett has the anti-rattle spring in the correct position, with the loop part sticking out on the same side of the mounting plate as the friction surface and rivet/lug.
My HD workshop manual emphasises “The spring clip loop and friction material must always face away from the piston”
Cheers Brett
Steve Wray - 답글
Well dictated, easy to follow, nice to see that my “winging it” was very close to these instructions!
Mark Dupré - 답글
Great tutorial- the photos are excellent. One think I noticed- in the manual, at least for my 1997 Sportster, the torque setting for the caliper-to-fork bolts is 25-35 FOOT-pounds, not inch-pounds. In-lbs would be too light, I think.
