소개
Although there have been some minor changes to the Sportster over the years, the oil change procedure for all 1986-present models is the same. This guide uses a 1998 Sportster as an example.
필요한 것
Securing the bike in an upright position allows for easier access to the drain tube.
This tube is attached by a house clamp to a nipple welded to the frame.
Loosen the house clamp with a Flathead Screwdriver. Do not remove the tube until you have your drain pan in position.
Pull the hose free from it's nipple and allow the oil to drain into your drain pan.
When the oil slows to a drip, replace the hose. Do not tighten the clamp yet, we will return for that later.
Open 1 quart of oil. Pour it into the filter until the filter is about 1/2 full.
Apply a small amount of clean oil to the rubber gasket on the new oil filter.
Wipe down the oil filter mounting area, and any oil residue that has run down onto the motorcycle.
Move the drain pan back underneath the oil drain tube. By this time more oil will have collected in it. Remove the tube again, and allow it to run out until it is just a light drip.
Reinstall the oil drain tube on its nipple, tightening the hose clamp with a flathead Screwdriver.
Pull the oil cap/dipstick off of the oil tank.
Using your funnel, slowly pour 3 quarts of oil into your oil tank.
Use the oilcap/dipstick to check your engine oil level (holding the bike level if you have been working with your side-stand). You oil level should be kept between the 2 dipstick marks. After refilling with 3 quarts it should be right to the top one.
It is a good idea to start your engine and let it run for a few minutes. Check your drain tube and oil filter for leaks. Recheck your oil level, and adjust if needed.
다른 87명이 해당 안내서를 완성하였습니다.
댓글 33개
One of the most helpful guides on a sportster oil change.
You may be able to use a Form-A-Funnel (Pig Funnel) to catch the oil from the filter.
http://www.formafunnel.com/buyNow.html
IF(!) I owned a Hardley like this, i would keep an eye on the drain hose for deterioration or road debris damage, and probably carry a spare hose. Also, a vandal could loosen the clamp or cut the hose.
Very helpful, simple instruction, good pictures
Best oil change I've read. Easy and hard to make mistakes. A+
Eric Essen: G. bless your generations forever. Manu, Brazil.
Manu Costa - 답글
