주요 콘텐츠로 건너뛰기
Harman Kardon Esquire Mini Battery Replacement
필요한 것
  1. Harman Kardon Esquire Mini Battery Replacement, Front Panel: 1 단계, 이미지 1/1
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini Battery Replacement: 2 단계, 이미지 1/1
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Harman Kardon Esquire Mini Battery Replacement, Battery: 3 단계, 이미지 1/1
    • After removing the front panel, remove the battery from its plug using a small amount of force.
    • Do not to break the battery plug, be gentle.
  4. Harman Kardon Esquire Mini Battery Replacement: 4 단계, 이미지 1/1
    • Remove the battery by using a plastic opening tool, by applying an upward force.
    • Be careful to not tear the electric wires.
결론
다른 4명이 해당 안내서를 완성하였습니다.
yousef aljeemaz
회원 가입일: 10/18/17
1,039 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G9, Cagle Fall 2017 USF Tampa, Team S1-G9, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G9
5 회원들
안내서 5개 작성하였습니다
댓글 4개
Between steps 3 and 4 I needed to disconnect the red speaker cable (right speaker step 4 image). I can see you didn't need to. The cable came out and returned to a socket.
Antony Cartwright - 답글
Where do I get a new battery?
Dennis Easter - 답글
I was able to follow this guide to disassemble my Harman/Kardon Esquire 2 speaker to also replace the battery, which had dropped to only holding about 20m charge.
Process is almost identical, just a bigger unit/speaker.
The battery in this unit was a "GSP805070" 3.7V 3200mAh, 11.84Wh Lithium Polymer, this had swollen to nearly double its thickness.
I was able to find a 3500mAh replacement on eBay.
anonymuchacho - 답글
Between steps 2 and 3, you have to unscrew the motherboard to get to the battery. Also, there is a bead of (probably) waterproofing glue holding things together. Just be gentle and careful, and the repair is doable with some skill. Not something for the total novice to attempt, but without this guide I would probably would not have repaired this unit, which was given to me as a gift, but had been in the original box for a number of years and was dead on opening. Thanks for the guide!
Bob McNabb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 18
30일 전: 59
전체 시간: 6,928
