주요 콘텐츠로 건너뛰기
Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's
필요한 것
  1. Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's, Front Panel: 1 단계, 이미지 1/1
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's: 2 단계, 이미지 1/1
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
  3. Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's, Buttons and Charging Indicator Lights's: 3 단계, 이미지 1/1
    • The buttons will be on the side of the device, use the plastic opening tool to remove it from its actual place no need to use any screwdrivers.
  4. Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's: 4 단계, 이미지 1/1
    • Use the plastic opening tool to remove the indicator lights and replace them by new ones.
결론
yousef aljeemaz
회원 가입일: 10/18/17
1,039 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G9, Cagle Fall 2017 USF Tampa, Team S1-G9, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G9
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 1,473
