주요 콘텐츠로 건너뛰기
Harman Kardon Invoke Service Port Replacement
필요한 것
  1. Harman Kardon Invoke Service Port Replacement, Remove the rubber base: 1 단계, 이미지 1/2 Harman Kardon Invoke Service Port Replacement, Remove the rubber base: 1 단계, 이미지 2/2
    • Use a metal spudger to remove the rubber bottom.
  2. Harman Kardon Invoke Service Port Replacement, Remove the base screws: 2 단계, 이미지 1/2 Harman Kardon Invoke Service Port Replacement, Remove the base screws: 2 단계, 이미지 2/2
    • Use a #10 Torx screwdriver to remove four 14 mm screws.
  3. Harman Kardon Invoke Service Port Replacement, Remove the base: 3 단계, 이미지 1/2 Harman Kardon Invoke Service Port Replacement, Remove the base: 3 단계, 이미지 2/2
    • Firmly grip the bottom and wiggle upwards to remove the base.
  4. Harman Kardon Invoke Service Port Replacement, Removing the board: 4 단계, 이미지 1/3 Harman Kardon Invoke Service Port Replacement, Removing the board: 4 단계, 이미지 2/3 Harman Kardon Invoke Service Port Replacement, Removing the board: 4 단계, 이미지 3/3
    • Use a #10 Torx screwdriver to remove two 10 mm screws from board attached to ports.
    • Pull board up lightly.
  5. Harman Kardon Invoke Service Port Replacement, Disconnect the board: 5 단계, 이미지 1/2 Harman Kardon Invoke Service Port Replacement, Disconnect the board: 5 단계, 이미지 2/2
    • Pull cable to disconnect board from device.
    • For replacement of service port, you will have to replace whole board that the port is attached to.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Angel A. Grageda
회원 가입일: 10/02/18
686 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 21
전체 시간: 1,002
