주요 콘텐츠로 건너뛰기
Harman Kardon Invoke Speaker Replacement
필요한 것
  1. Harman Kardon Invoke Speaker Replacement, Speakers: 1 단계, 이미지 1/3 Harman Kardon Invoke Speaker Replacement, Speakers: 1 단계, 이미지 2/3 Harman Kardon Invoke Speaker Replacement, Speakers: 1 단계, 이미지 3/3
    • Use metal spudger to remove top cover from smart speaker.
    • Use the Phillips #2 screwdriver, remove the three 17mm screws.
  2. Harman Kardon Invoke Speaker Replacement: 2 단계, 이미지 1/3 Harman Kardon Invoke Speaker Replacement: 2 단계, 이미지 2/3 Harman Kardon Invoke Speaker Replacement: 2 단계, 이미지 3/3
    • Once the 17 mm screws are removed, lift the volume wheel.
    • Lift slowly as you do not want to damage the cable connected to the LED board.
    • Pull lightly on the cable in order to remove both the volume wheel and LED board.
  3. Harman Kardon Invoke Speaker Replacement: 3 단계, 이미지 1/3 Harman Kardon Invoke Speaker Replacement: 3 단계, 이미지 2/3 Harman Kardon Invoke Speaker Replacement: 3 단계, 이미지 3/3
    • Use the Torx #10 screwdriver, remove the four 14 mm screws around the lid.
    • Remove lid.
  4. Harman Kardon Invoke Speaker Replacement: 4 단계, 이미지 1/3 Harman Kardon Invoke Speaker Replacement: 4 단계, 이미지 2/3 Harman Kardon Invoke Speaker Replacement: 4 단계, 이미지 3/3
    • Once lid is removed, housing can now slide upwards.
    • Use the Torx #10 screwdriver, remove both 10 mm screws for each speaker that must be replaced.
  5. Harman Kardon Invoke Speaker Replacement: 5 단계, 이미지 1/1
    • Pull on the speaker cables lightly in order to detach the speakers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Angel A. Grageda
회원 가입일: 10/02/18
686 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 15
전체 시간: 1,275
