소개
Is the audio from your Invoke smart speaker distorted or scratchy? If so, one of the three speakers in your invoke might need to be replaced. All you need for this replacement is a Phillips #2 screw driver, a Torx #10 screw driver and a metal spudger tool.
필요한 것
Use metal spudger to remove top cover from smart speaker.
Use the Phillips #2 screwdriver, remove the three 17mm screws.
다른 2명이 해당 안내서를 완성하였습니다.
