소개
After removing the control board and circuit board, the Bluetooth antenna can be accessed and therefore removed. This is helpful if a lack of Bluetooth connectivity is due to the speaker.
필요한 것
Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
Disconnect the remaining connectors from the circuit board.
Disconnect the Bluetooth antenna.
Using the wide blue plastic opening tool, gently peel back edges of the Bluetooth board.
Peel off completely and remove from the device.
다른 4명이 해당 안내서를 완성하였습니다.
