주요 콘텐츠로 건너뛰기
Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement
필요한 것
  1. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Front Panel: 1 단계, 이미지 1/3 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Front Panel: 1 단계, 이미지 2/3 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Front Panel: 1 단계, 이미지 3/3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: 2 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: 2 단계, 이미지 2/2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: 3 단계, 이미지 1/1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: 4 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: 4 단계, 이미지 2/2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Control Board: 5 단계, 이미지 1/1
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: 6 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: 6 단계, 이미지 2/2
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: 7 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: 7 단계, 이미지 2/2
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
  8. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Circuit Board: 8 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Circuit Board: 8 단계, 이미지 2/2
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: 9 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement: 9 단계, 이미지 2/2
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
  10. Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Bluetooth Antenna: 10 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Bluetooth Antenna Replacement, Bluetooth Antenna: 10 단계, 이미지 2/2
    • Using the wide blue plastic opening tool, gently peel back edges of the Bluetooth board.
    • Peel off completely and remove from the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Alexandra Achtenberg
회원 가입일: 02/02/17
2,051 평판
안내서 6개 작성하였습니다
USF Tampa, Team 16-5, Blackwell Spring 2017 USF Tampa, Team 16-5, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G5
3 회원들
안내서 24개 작성하였습니다
댓글 한 개
Any idea where we can purchase the replacement parts?
Cort Krause - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 28
전체 시간: 9,537
