주요 콘텐츠로 건너뛰기
Harman Kardon Onyx Studio 2 Control Board Replacement
필요한 것
  1. Harman Kardon Onyx Studio 2 Control Board Replacement, Front Panel: 1 단계, 이미지 1/3 Harman Kardon Onyx Studio 2 Control Board Replacement, Front Panel: 1 단계, 이미지 2/3 Harman Kardon Onyx Studio 2 Control Board Replacement, Front Panel: 1 단계, 이미지 3/3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Control Board Replacement: 2 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Control Board Replacement: 2 단계, 이미지 2/2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Control Board Replacement: 3 단계, 이미지 1/1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Control Board Replacement: 4 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Control Board Replacement: 4 단계, 이미지 2/2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Control Board Replacement, Control Board: 5 단계, 이미지 1/1
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Control Board Replacement: 6 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Control Board Replacement: 6 단계, 이미지 2/2
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Control Board Replacement: 7 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Control Board Replacement: 7 단계, 이미지 2/2
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Alexandra Achtenberg
회원 가입일: 02/02/17
2,051 평판
안내서 6개 작성하였습니다
USF Tampa, Team 16-5, Blackwell Spring 2017 USF Tampa, Team 16-5, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G5
3 회원들
안내서 24개 작성하였습니다
댓글 9개
Do you guys know where to get a control board, because my board is broken so i am looking for one
Zhou Yuqi - 답글
Where to get control board onyx 2.
Mike Champagne - 답글
My on/off button keeps blinking…..would somebody please email me cause I am a techno nitwit……..i’m gonna bring this piece of non chargeable crap outside and go Italian on it with the 12 gauge! SERENITY NOW!
Sincerely,
email ; jorcal3318@aol.com
Frank Vitolo - 답글
power button continually blinks. Won’t turn on, can’t pair, no other action can be taken, just the blinking power button. what’s the solution? Please share….
rachael friesen -
Speaker plays for split second then fades away like wtf
Paul Berrellez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 50
전체 시간: 14,315
