주요 콘텐츠로 건너뛰기
Harman Kardon Onyx Studio 2 Front Panel Replacement
필요한 것
  1. Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: 1 단계, 이미지 1/3 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: 1 단계, 이미지 2/3 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: 1 단계, 이미지 3/3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Front Panel Replacement: 2 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Front Panel Replacement: 2 단계, 이미지 2/2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Front Panel Replacement: 3 단계, 이미지 1/1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Front Panel Replacement: 4 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Front Panel Replacement: 4 단계, 이미지 2/2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
결론
To reassemble, follow these steps in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Alexandra Achtenberg
회원 가입일: 02/02/17
2,031 평판
안내서 6개 작성하였습니다
USF Tampa, Team 16-5, Blackwell Spring 2017 USF Tampa, Team 16-5, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G5
3 회원들
안내서 24개 작성하였습니다
댓글 한 개
Hi, I have the ONYX STUDIO with the silver ring that serves as the stand and the handle at the same time. After removing the front grill, I find the same five holes as it is shown on your pics but there are no screws. I can just see a bottom made of plastic. Do you have experience with that? Is that just some cover I can get thru using a screwdriver and I find the screws beneath?
I want to look inside as I am facing the problem with not working battery. As soon as I unplug the power source, it stops working.
Thank you for your comments.
Vaclav Matoulek - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 43
전체 시간: 6,036
