주요 콘텐츠로 건너뛰기
Harman Kardon Onyx Studio 2 Speakers Replacement
필요한 것
  1. Harman Kardon Onyx Studio 2 Speakers Replacement, Front Panel: 1 단계, 이미지 1/3 Harman Kardon Onyx Studio 2 Speakers Replacement, Front Panel: 1 단계, 이미지 2/3 Harman Kardon Onyx Studio 2 Speakers Replacement, Front Panel: 1 단계, 이미지 3/3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Speakers Replacement: 2 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Speakers Replacement: 2 단계, 이미지 2/2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Speakers Replacement: 3 단계, 이미지 1/1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Speakers Replacement: 4 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Speakers Replacement: 4 단계, 이미지 2/2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
  5. Harman Kardon Onyx Studio 2 Speakers Replacement, Control Board: 5 단계, 이미지 1/1
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Speakers Replacement: 6 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Speakers Replacement: 6 단계, 이미지 2/2
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Speakers Replacement: 7 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Speakers Replacement: 7 단계, 이미지 2/2
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
  8. Harman Kardon Onyx Studio 2 Speakers Replacement, Circuit Board: 8 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Speakers Replacement, Circuit Board: 8 단계, 이미지 2/2
    • Disconnect the remaining connectors from the circuit board.
    • Disconnect the Bluetooth antenna.
  9. Harman Kardon Onyx Studio 2 Speakers Replacement: 9 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Speakers Replacement: 9 단계, 이미지 2/2
    • Remove the four 10 mm T10 Torx screws.
    • Pull the circuit board out of the device as it is now free.
  10. Harman Kardon Onyx Studio 2 Speakers Replacement, Speakers: 10 단계, 이미지 1/1
    • Using the metal spudger, gently pry off the two red and black connectors.
  11. Harman Kardon Onyx Studio 2 Speakers Replacement: 11 단계, 이미지 1/2 Harman Kardon Onyx Studio 2 Speakers Replacement: 11 단계, 이미지 2/2
    • Remove the four 14.3 mm T10 Torx screws.
  12. Harman Kardon Onyx Studio 2 Speakers Replacement: 12 단계, 이미지 1/1
    • Pull out the speaker, and if necessary follow these steps to replace the other identical speaker.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Alexandra Achtenberg
회원 가입일: 02/02/17
2,051 평판
안내서 6개 작성하였습니다
USF Tampa, Team 16-5, Blackwell Spring 2017 USF Tampa, Team 16-5, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G5
3 회원들
안내서 24개 작성하였습니다
댓글 2개
Hi, do anyone know sparepart number for woofer elements?
Mikko Lehto - 답글
Hello.. what is the wattage of the speaker? and where can i get a replacement. how much?
James Santiago - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 27
30일 전: 98
전체 시간: 19,756
