주요 콘텐츠로 건너뛰기
Hasbro Bop-It Micro Series Levers Replacement
필요한 것
  1. Hasbro Bop-It Micro Series Levers Replacement, Back Case: 1 단계, 이미지 1/1
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Levers Replacement: 2 단계, 이미지 1/1
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Levers Replacement: 3 단계, 이미지 1/1
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Levers Replacement, Levers: 4 단계, 이미지 1/1
    • Observe the orientation of the levers before removal.
    • Remove the white plastic levers with your fingers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Glenn Haag
회원 가입일: 09/29/16
479 평판
안내서 3개 작성하였습니다
IUPUI, Team 3-1, Harley Fall 2016 IUPUI, Team 3-1, Harley Fall 2016 회원
IUPUI-HARLEY-F16S3G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 26
전체 시간: 1,864
