주요 콘텐츠로 건너뛰기
Hasbro Bop-It Micro Series Speaker Replacement
필요한 것
  1. Hasbro Bop-It Micro Series Speaker Replacement, Back Case: 1 단계, 이미지 1/1
    • Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
  2. Hasbro Bop-It Micro Series Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
    • When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
  3. Hasbro Bop-It Micro Series Speaker Replacement: 3 단계, 이미지 1/1
    • Carefully separate the two sections, leaving them connected by the wires.
  4. Hasbro Bop-It Micro Series Speaker Replacement, Speaker: 4 단계, 이미지 1/2 Hasbro Bop-It Micro Series Speaker Replacement, Speaker: 4 단계, 이미지 2/2
    • Remove the (3) #3 Phillips head 6 mm screws using your Phillips #0 screwdriver, and remove the plastic with your fingers.
  5. Hasbro Bop-It Micro Series Speaker Replacement: 5 단계, 이미지 1/1
    • De-solder the speaker from the wires. Refer to the soldering guide for instructions on how to solder
결론
Follow the steps of this guide in reverse to reassemble.
다른 2명이 해당 안내서를 완성하였습니다.
Glenn Haag
회원 가입일: 09/29/16
479 평판
안내서 3개 작성하였습니다
IUPUI, Team 3-1, Harley Fall 2016 IUPUI, Team 3-1, Harley Fall 2016 회원
IUPUI-HARLEY-F16S3G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 22
전체 시간: 1,256
