소개
This guide will show you how to replace the Furby's light sensor circuit board.
필요한 것
Use a flathead screwdriver to remove the two 10mm screws on the base of the Furby.
Remove the 10mm Phillips #0 screw holding the circuit board in.
Gently lift out the circuit board.
이 단계에 사용된 도구:Tweezers$4.99
Orient the Furby with the tail pointing left and the face pointing right.
Use the pointed tweezers to spread open the socket, and the blunt tweezers to grip and tug out the connector.
Insert your replacement light sensor connector.
다른 한 분이 해당 안내서를 완성하였습니다.
